Philco speaker
Arran,
If I install the filter choke to compensate for the lesser resistance, won't the max. output suffer due to the lower current going through the field coil?
Philco speaker - by fields 100 - 07-13-2014, 07:33 AM
RE: Philco speaker - by morzh - 07-13-2014, 10:22 AM
RE: Philco speaker - by Steve Davis - 07-13-2014, 10:49 AM
RE: Philco speaker - by morzh - 07-13-2014, 11:10 AM
RE: Philco speaker - by Arran - 07-13-2014, 11:36 AM
RE: Philco speaker - by fields 100 - 07-13-2014, 12:33 PM
RE: Philco speaker - by fields 100 - 07-13-2014, 01:26 PM
RE: Philco speaker - by Arran - 07-13-2014, 01:33 PM
RE: Philco speaker - by morzh - 07-13-2014, 01:56 PM
RE: Philco speaker - by fields 100 - 07-13-2014, 03:44 PM
RE: Philco speaker - by morzh - 07-13-2014, 04:15 PM
RE: Philco speaker - by codefox1 - 07-13-2014, 05:25 PM
There are currently 4034 online users. [Complete List]
» 1 Member(s) | 4033 Guest(s)
