Philco speaker
Morzh,
You correctly mentioned earlier that the amp/turns determine inductance. Won't,by adding either the choke or resistor for that matter, reduce the current, cutting down the max. available speaker output and if so, how bad this reduction roughly will be ?
Philco speaker - by fields 100 - 07-13-2014, 07:33 AM
RE: Philco speaker - by morzh - 07-13-2014, 10:22 AM
RE: Philco speaker - by Steve Davis - 07-13-2014, 10:49 AM
RE: Philco speaker - by morzh - 07-13-2014, 11:10 AM
RE: Philco speaker - by Arran - 07-13-2014, 11:36 AM
RE: Philco speaker - by fields 100 - 07-13-2014, 12:33 PM
RE: Philco speaker - by fields 100 - 07-13-2014, 01:26 PM
RE: Philco speaker - by Arran - 07-13-2014, 01:33 PM
RE: Philco speaker - by morzh - 07-13-2014, 01:56 PM
RE: Philco speaker - by fields 100 - 07-13-2014, 03:44 PM
RE: Philco speaker - by morzh - 07-13-2014, 04:15 PM
RE: Philco speaker - by codefox1 - 07-13-2014, 05:25 PM
There are currently 3413 online users. [Complete List]
» 1 Member(s) | 3412 Guest(s)
