  • 1 Vote(s) - 5 Average
Philco 20 Donated Finished
See above.
SOME of those were made in a mold. Some actually have the wire wrapped around the end like the originals. This is usually on the 1 watt and larger, which I usually use a 9 to 10 watt resistor inside. Heat must be controlled since the bodies of MOST are plastic. I have melted one in a circuit, but it was a fault rater than function.
P.S. IT IS IMPORTANT to note at this time that black automotive tubing is CONDUCTIVE. Yah, ask me how I know. It did seem like the perfect cover for those old AK power leads like in the 55s and 60s - NOT!
Philco 20 Donated Finished - by Phlogiston - 06-12-2014, 06:41 PM
RE: Philco 20 Donated - by morzh - 06-12-2014, 07:23 PM
RE: Philco 20 Donated - by klondike98 - 06-12-2014, 09:33 PM
RE: Philco 20 Donated - by Arran - 06-12-2014, 10:16 PM
RE: Philco 20 Donated - by morzh - 06-12-2014, 10:20 PM
RE: Philco 20 Donated - by Phlogiston - 06-12-2014, 10:56 PM
RE: Philco 20 Donated - by GarySP - 06-13-2014, 12:13 PM
RE: Philco 20 Donated - by morzh - 06-13-2014, 03:09 PM
RE: Philco 20 Donated - by Phlogiston - 06-13-2014, 03:27 PM
RE: Philco 20 Donated - by morzh - 06-13-2014, 03:35 PM
RE: Philco 20 Donated - by Phlogiston - 06-13-2014, 06:10 PM
RE: Philco 20 Donated - by Randy H. - 06-16-2014, 04:17 PM
RE: Philco 20 Donated - by morzh - 06-16-2014, 04:23 PM
RE: Philco 20 Donated - by Phlogiston - 07-13-2014, 01:51 AM
RE: Philco 20 Donated - by morzh - 07-13-2014, 10:27 AM
RE: Philco 20 Donated - by Steve Davis - 07-13-2014, 10:39 AM
RE: Philco 20 Donated - by klondike98 - 07-13-2014, 10:45 AM
RE: Philco 20 Donated - by Phlogiston - 07-13-2014, 03:02 PM
RE: Philco 20 Donated - by Phlogiston - 07-13-2014, 08:40 PM
RE: Philco 20 Donated - by morzh - 07-13-2014, 09:31 PM
RE: Philco 20 Donated - by Phlogiston - 07-14-2014, 02:49 AM
RE: Philco 20 Donated - by morzh - 07-14-2014, 08:18 AM
RE: Philco 20 Donated - by Phlogiston - 07-14-2014, 08:45 AM
RE: Philco 20 Donated - by morzh - 07-14-2014, 08:48 AM
RE: Philco 20 Donated - by Phlogiston - 07-14-2014, 09:14 AM
RE: Philco 20 Donated - by klondike98 - 07-14-2014, 09:21 AM
RE: Philco 20 Donated - by Phlogiston - 07-14-2014, 09:36 AM
RE: Philco 20 Donated - by morzh - 07-14-2014, 09:56 AM
RE: Philco 20 Donated Finished - by Phlogiston - 07-17-2014, 01:33 PM
RE: Philco 20 Donated Finished - by morzh - 07-17-2014, 01:49 PM
RE: Philco 20 Donated Finished - by Phlogiston - 07-17-2014, 07:06 PM
RE: Philco 20 Donated Finished - by klondike98 - 07-17-2014, 10:22 PM
RE: Philco 20 Donated Finished - by Phlogiston - 07-18-2014, 12:33 AM
RE: Philco 20 Donated Finished - by Eliot Ness - 07-18-2014, 09:33 AM
There are currently 9736 online users. [Complete List]
» 3 Member(s) | 9733 Guest(s)
