37-116 and 118
No it did not.
Anyway, will show it to you tomorrow.
Now we'll have to figure out hot to get ot to you.
Ain't gonna be cheap, I could tell.
Will need to ask a UPS store to pack it, it is above my abilities.
And buy a piece of plywood to screw to the bottom of the chassis.
Will probably leave the speaker and clarifiers in the cabinet.
I will also take off the dial and the band light indicator wheel, put it ia a padded envelope and tape it inside the cabinet.
37-116 and 118 - by morzh - 07-12-2014, 09:37 PM
RE: 37-116 and 118 - by Phlogiston - 07-12-2014, 10:00 PM
RE: 37-116 and 118 - by morzh - 07-12-2014, 10:36 PM
RE: 37-116 and 118 - by RadioSvit - 07-14-2014, 12:24 PM
RE: 37-116 and 118 - by morzh - 07-14-2014, 12:26 PM
RE: 37-116 and 118 - by RadioSvit - 07-14-2014, 02:04 PM
RE: 37-116 and 118 - by morzh - 07-14-2014, 02:51 PM
RE: 37-116 and 118 - by morzh - 07-17-2014, 03:18 PM
