Philco 48-1256 (was: Bulb Identification)
Shot an email out to the vintage electronics.com contact, quoted about $30 for pin and new cartridge. Probably going to go that route. Wired up the phono, everything seems to function fine minus the sound of course. But I do need a new set screw for the bottom of the arm where it meets the base. This isn't the needle screw but the bottom of the arm. Does anybody know what type of screw this would be? Btw, everyone's help here has been great, made this process very easy. Next step is going to be sanding down the metal phono surface and repainting it somehow, it is currently rusted and pitting in spots.
RE: Bulb Identification - by Eric Adams - 07-09-2014, 01:14 AM
RE: Bulb Identification - by klondike98 - 07-09-2014, 12:22 PM
RE: Bulb Identification - by Carl Travis - 07-09-2014, 02:35 PM
RE: Bulb Identification - by klondike98 - 07-09-2014, 03:41 PM
RE: Bulb Identification - by KidCarter - 07-09-2014, 04:02 PM
RE: Bulb Identification - by Carl Travis - 07-09-2014, 04:31 PM
RE: Bulb Identification - by KidCarter - 07-09-2014, 06:08 PM
RE: Bulb Identification - by KidCarter - 07-09-2014, 10:19 PM
RE: Bulb Identification - by Warren - 07-10-2014, 12:08 AM
RE: Bulb Identification - by KidCarter - 07-12-2014, 11:31 AM
RE: Bulb Identification - by klondike98 - 07-12-2014, 05:19 PM
RE: Bulb Identification - by codefox1 - 07-13-2014, 01:14 PM
RE: Bulb Identification - by KidCarter - 07-14-2014, 07:35 PM
RE: Bulb Identification - by Squire - 07-19-2014, 12:08 PM
RE: Bulb Identification - by KidCarter - 07-19-2014, 11:24 PM
RE: Bulb Identification - by Squire - 07-20-2014, 12:54 AM
RE: Bulb Identification - by Warren - 07-20-2014, 02:32 AM
RE: Bulb Identification - by klondike98 - 07-20-2014, 10:09 AM
RE: Bulb Identification - by KidCarter - 07-20-2014, 11:04 AM
RE: Bulb Identification - by Squire - 07-20-2014, 01:14 PM
RE: Bulb Identification - by KidCarter - 07-21-2014, 09:55 PM
RE: Bulb Identification - by Warren - 07-21-2014, 11:26 PM
New member
Philco 630csx power cord
New member
There are currently 3941 online users. [Complete List]
» 2 Member(s) | 3939 Guest(s)
