Wire wound resistor
Hello everyone. Since you're all running out of rhymes anyway, I thought I would answer Mike's earlier question. I researched the data on corona dope, and couldn't find what it's thermal properties were. However, a company called MG chemicals makes red insulating lacquer. It offers insulating level of 3100v per mil, and thermal protection to 155 C (311 F). If the resistor is still within specs this would probably do the trick. So, skip the dope, don't mope, never give up hope, even if you're at the end of your rope, run to the supplier at a steady lope, and pick up a bottle to try. Could I find a rhyme to end the last sentence? NOPE!!! Take care, Gary
Wire wound resistor - by fields 100 - 07-11-2014, 08:52 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 09:16 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 10:01 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:11 PM
RE: Wire wound resistor - by Warren - 07-11-2014, 10:50 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 10:56 PM
RE: Wire wound resistor - by morzh - 07-11-2014, 11:00 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:03 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:05 PM
RE: Wire wound resistor - by fields 100 - 07-11-2014, 11:12 PM
RE: Wire wound resistor - by Mondial - 07-11-2014, 11:20 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:16 AM
RE: Wire wound resistor - by GarySP - 07-12-2014, 09:30 AM
RE: Wire wound resistor - by morzh - 07-12-2014, 09:46 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:01 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 10:37 PM
RE: Wire wound resistor - by fields 100 - 07-12-2014, 10:47 PM
RE: Wire wound resistor - by morzh - 07-12-2014, 11:01 PM
RE: Wire wound resistor - by codefox1 - 07-13-2014, 12:55 PM
RE: Wire wound resistor - by morzh - 07-13-2014, 02:02 PM
RE: Wire wound resistor - by GarySP - 07-15-2014, 08:29 AM
RE: Wire wound resistor - by morzh - 07-15-2014, 08:48 AM
RE: Wire wound resistor - by fields 100 - 07-15-2014, 10:15 AM
RE: Wire wound resistor - by tom.seeger - 07-15-2014, 10:51 AM
RE: Wire wound resistor - by TV MAN - 07-19-2014, 09:16 AM
RE: Wire wound resistor - by codefox1 - 07-21-2014, 10:32 AM
New member
Philco 630csx power cord
New member
There are currently 4017 online users. [Complete List]
» 1 Member(s) | 4016 Guest(s)
