39-25 Project
A technical question for you guys.  A previous repair has replaced the #42 280 ohm wire wound resistor (Part No. 33-128431) with a 10 watt 250 ohm resistor.  They also replaced the # 43 70 ohm 1/2 watt resistor with what looks like another 10 watt replacement. Probably OK but it sure is ugly.  I'm replacing the 70 ohm with a correct reproduction.  Any suggestions on what to do with replacing the 280 ohm?  I have a much smaller 5 watt 300 ohm part that would be easier to hide but I'm not sure of what wattage I can actually use.  Anyone have specs on the original part or an assessment of the wattage required?  Thanks!!
[Image: https://www.dropbox.com/s/e7anw9z01323sf....jpg?raw=1]
[Image: https://www.dropbox.com/s/g5tw19ucly5z5y....jpg?raw=1]
39-25 Project - by klondike98 - 02-07-2014, 12:11 AM
RE: 39-25 Project - by tab10672 - 02-07-2014, 12:14 AM
RE: 39-25 Project - by morzh - 02-07-2014, 10:56 AM
RE: 39-25 Project - by klondike98 - 02-07-2014, 11:36 AM
RE: 39-25 Project - by klondike98 - 02-20-2014, 10:40 AM
RE: 39-25 Project - by Tom Hamilton - 02-25-2014, 12:57 PM
RE: 39-25 Project - by klondike98 - 02-25-2014, 02:08 PM
RE: 39-25 Project - by klondike98 - 02-25-2014, 02:53 PM
RE: 39-25 Project - by Tom Hamilton - 02-25-2014, 07:22 PM
RE: 39-25 Project - by shaler78 - 02-25-2014, 08:42 PM
RE: 39-25 Project - by klondike98 - 02-25-2014, 11:17 PM
RE: 39-25 Project - by klondike98 - 03-08-2014, 11:07 PM
RE: 39-25 Project - by Ron Ramirez - 03-09-2014, 12:14 AM
RE: 39-25 Project - by klondike98 - 03-09-2014, 08:30 AM
RE: 39-25 Project - by Joeztech - 03-23-2014, 04:12 PM
RE: 39-25 Project - by klondike98 - 03-23-2014, 04:48 PM
RE: 39-25 Project - by morzh - 03-23-2014, 06:10 PM
RE: 39-25 Project - by klondike98 - 03-23-2014, 06:27 PM
RE: 39-25 Project - by OldRestorer - 03-23-2014, 09:38 PM
RE: 39-25 Project - by klondike98 - 03-25-2014, 02:04 PM
RE: 39-25 Project - by Chuck Schwark - 03-25-2014, 02:21 PM
RE: 39-25 Project - by klondike98 - 03-25-2014, 02:34 PM
RE: 39-25 Project - by Tom Hamilton - 03-26-2014, 01:51 AM
RE: 39-25 Project - by klondike98 - 07-15-2014, 07:27 PM
RE: 39-25 Project - by klondike98 - 07-15-2014, 07:50 PM
RE: 39-25 Project - by morzh - 07-15-2014, 09:09 PM
RE: 39-25 Project - by klondike98 - 07-16-2014, 10:43 AM
RE: 39-25 Project - by morzh - 07-16-2014, 03:57 PM
RE: 39-25 Project - by klondike98 - 07-16-2014, 08:22 PM
RE: 39-25 Project - by klondike98 - 07-21-2014, 12:26 PM
RE: 39-25 Project - by Radioroslyn - 07-21-2014, 01:18 PM
RE: 39-25 Project - by klondike98 - 07-21-2014, 05:27 PM
New member
Philco 630csx power cord
New member
There are currently 3007 online users. [Complete List]
» 5 Member(s) | 3002 Guest(s)
AvatarAvatarAvatarAvatar
