  • 1 Vote(s) - 5 Average
Philco 66 Restoration Chronicles
It was not eaten through, A seam popped from shoddy craftsmanship.
It is a metal can.
Grrrrrrrr.
Philco 66 Restoration Chronicles - by OldRestorer - 07-04-2014, 12:58 PM
RE: Philco 66 Restoration Chronicles - by morzh - 07-04-2014, 03:24 PM
RE: Philco 66 Restoration Chronicles - by morzh - 07-10-2014, 10:34 AM
RE: Philco 66 Restoration Chronicles - by morzh - 07-15-2014, 04:33 PM
RE: Philco 66 Restoration Chronicles - by Arran - 07-16-2014, 02:28 AM
RE: Philco 66 Restoration Chronicles - by OldRestorer - 07-16-2014, 07:32 AM
RE: Philco 66 Restoration Chronicles - by morzh - 07-16-2014, 10:10 AM
RE: Philco 66 Restoration Chronicles - by morzh - 07-16-2014, 04:01 PM
RE: Philco 66 Restoration Chronicles - by morzh - 07-27-2014, 11:09 AM
RE: Philco 66 Restoration Chronicles - by morzh - 08-08-2014, 02:12 PM
RE: Philco 66 Restoration Chronicles - by Warren - 08-09-2014, 12:21 AM
RE: Philco 66 Restoration Chronicles - by morzh - 08-09-2014, 09:48 AM
RE: Philco 66 Restoration Chronicles - by morzh - 08-09-2014, 03:30 PM
RE: Philco 66 Restoration Chronicles - by sam - 08-10-2014, 10:00 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-10-2014, 10:06 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-11-2014, 11:16 AM
RE: Philco 66 Restoration Chronicles - by morzh - 08-11-2014, 12:39 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-20-2014, 01:30 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-20-2014, 02:23 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-20-2014, 03:21 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-20-2014, 05:32 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-20-2014, 05:40 PM
RE: Philco 66 Restoration Chronicles - by morzh - 08-27-2014, 11:50 AM
RE: Philco 66 Restoration Chronicles - by Warren - 08-27-2014, 04:08 PM
RE: Philco 66 Restoration Chronicles - by Warren - 08-28-2014, 06:32 PM
RE: Philco 66 Restoration Chronicles - by morzh - 09-08-2014, 01:26 PM
Users browsing this thread: 18 Guest(s)
There are currently 10190 online users. [Complete List]
» 1 Member(s) | 10189 Guest(s)
