Grundig 5008
I'm soon to receive this radio from a friend. I don't know what shape it is in but I have NEVER worked on a Grundig before. As I understand, it has BC, SW, and FM bands. I'd appreciate any hints/tips/warnings/heads up on this set. I THINK it is a USA version but will have to wait for a bit to know. I believe there is a European version on this model as well.
Any help would be appreciated.
Art
Grundig 5008 - by Art Hoch - 07-16-2014, 11:51 AM
RE: Grundig 5008 - by morzh - 07-16-2014, 04:26 PM
RE: Grundig 5008 - by Art Hoch - 07-16-2014, 06:08 PM
RE: Grundig 5008 - by morzh - 07-16-2014, 08:46 PM
RE: Grundig 5008 - by Art Hoch - 07-20-2014, 09:14 AM
RE: Grundig 5008 - by Arran - 07-20-2014, 02:04 PM
RE: Grundig 5008 - by Art Hoch - 07-20-2014, 03:54 PM
RE: Grundig 5008 - by codefox1 - 07-20-2014, 10:13 PM
RE: Grundig 5008 - by Art Hoch - 07-20-2014, 11:27 PM
RE: Grundig 5008 - by gregb - 07-20-2014, 11:41 PM
RE: Grundig 5008 - by morzh - 07-20-2014, 11:48 PM
RE: Grundig 5008 - by Arran - 07-21-2014, 03:26 AM
RE: Grundig 5008 - by Art Hoch - 07-21-2014, 11:19 PM
RE: Grundig 5008 - by Art Hoch - 07-22-2014, 12:44 PM
RE: Grundig 5008 - by Art Hoch - 07-26-2014, 05:43 PM
RE: Grundig 5008 - by Art Hoch - 07-28-2014, 08:00 PM
RE: Grundig 5008 - by morzh - 07-28-2014, 11:05 PM
RE: Grundig 5008 - by Art Hoch - 07-29-2014, 11:18 AM
RE: Grundig 5008 - by morzh - 07-29-2014, 12:10 PM
RE: Grundig 5008 - by Art Hoch - 07-30-2014, 05:34 PM
RE: Grundig 5008 - by Arran - 07-30-2014, 08:08 PM
RE: Grundig 5008 - by Art Hoch - 07-31-2014, 10:46 AM
RE: Grundig 5008 - by Art Hoch - 08-04-2014, 09:16 PM
RE: Grundig 5008 - by murf - 08-06-2014, 08:02 PM
RE: Grundig 5008 - by Art Hoch - 08-08-2014, 08:35 PM
RE: Grundig 5008 - by murf - 08-08-2014, 09:00 PM
RE: Grundig 5008 - by Art Hoch - 08-09-2014, 10:20 PM
RE: Grundig 5008 - by Art Hoch - 08-09-2014, 10:24 PM
RE: Grundig 5008 - by Ron Ramirez - 08-10-2014, 07:25 AM
RE: Grundig 5008 - by Art Hoch - 08-13-2014, 06:06 PM
RE: Grundig 5008 - by Art Hoch - 08-22-2014, 02:24 PM
RE: Grundig 5008 - by Art Hoch - 08-29-2014, 12:41 PM
