Model 650B Tombstone Project
Ron,
You mentioned that the correct colors should be Van Dyke Brown and Medium Walnut. Do those color names pertain to an particular manufacturer?
I'm restoring a 620 and would like to get it right.
Derek
Model 650B Tombstone Project - by Ron Ramirez - 12-04-2005, 01:27 AM
[No subject] - by don'tdomelikethat - 12-04-2005, 10:11 AM
[No subject] - by Ron Ramirez - 12-04-2005, 05:26 PM
[No subject] - by don'tdomelikethat - 12-04-2005, 05:59 PM
[No subject] - by Ron Ramirez - 12-04-2005, 07:16 PM
[No subject] - by Bill Hutchinson - 12-04-2005, 09:00 PM
[No subject] - by Ron Ramirez - 12-06-2005, 12:04 PM
[No subject] - by Bill Hutchinson - 12-08-2005, 11:43 AM
[No subject] - by Derek D - 12-12-2005, 01:29 PM
[No subject] - by Ron Ramirez - 12-12-2005, 02:28 PM
[No subject] - by Ron Ramirez - 12-19-2005, 01:55 AM
Re: Model 650B Tombstone Project - by Ron Ramirez - 05-23-2011, 07:47 PM
