1931 Grandfather Clock/radio completed!
Easy. Become a grandfather (unless already are), and any clock you own becomes a grandfather clock.
A well trained parrot on a rope can say tic-tac while swinging.
And if you feel you have had enough you tell him to shut up.
Of course, him being a parrot, he can tell you to shut up right back.
This is where you remind him who puts the food in his feeder. And pluck a feather or to from his tail. That will get him in the respectful mood for a couple of month.
Make sure though he is not in cahoots with your wife.
1931 Grandfather Clock/radio completed! - by AI2V - 07-08-2014, 11:38 AM
RE: 1931 Grandfather Clock/radio completed! - by morzh - 07-16-2014, 09:41 PM
There are currently 10167 online users. [Complete List]
» 1 Member(s) | 10166 Guest(s)
