Stromberg Carlson 225-H restoration chronicles
Veneer repairs completed and top stripped. Need to color match the veneer repair and add some darker lines.
RE: Stromberg Carlson 225-H restoration chronicles - by OldRestorer - 07-17-2014, 08:08 AM
