RCA 68R3 Help
Ok, As the song says " I Can See Clearly Now" This is exactly my problems
I'm going to start at the bottom.
3 My slugs look about like yours about 5/16 on the right and 5/8 on the left.
2 I have no screw there I will put one there and solder the two parts of the chassis
1 The silver on the inside center part is pretty much eaten up the lower where you indicate is black. Can I resolder the part you indicate? Is it part c-33 2.5-13 mmf? Can I buy a replacement or put in a fixed?
RCA 68R3 Help - by Eric - 07-16-2014, 03:27 PM
RE: RCA 68R3 Help - by exray - 07-16-2014, 07:28 PM
RE: RCA 68R3 Help - by Eric - 07-16-2014, 09:28 PM
RE: RCA 68R3 Help - by Eric - 07-17-2014, 11:03 AM
RE: RCA 68R3 Help - by exray - 07-17-2014, 03:50 PM
RE: RCA 68R3 Help - by morzh - 07-17-2014, 04:18 PM
RE: RCA 68R3 Help - by exray - 07-17-2014, 06:08 PM
RE: RCA 68R3 Help - by Eric - 07-17-2014, 07:46 PM
RE: RCA 68R3 Help - by exray - 07-17-2014, 09:33 PM
RE: RCA 68R3 Help - by Eric - 07-21-2014, 05:24 PM
RE: RCA 68R3 Help - by exray - 07-21-2014, 08:16 PM
RE: RCA 68R3 Help - by Eric - 07-22-2014, 08:43 AM
There are currently 5747 online users. [Complete List]
» 1 Member(s) | 5746 Guest(s)
