37-116 and 118
Bought the chevron cloth from Kenny.
He promised to throw in two smaller pieces with centered center-line for the clarifiers.
Soon as it comes, I will ship the radio.
37-116 and 118 - by morzh - 07-12-2014, 09:37 PM
RE: 37-116 and 118 - by Phlogiston - 07-12-2014, 10:00 PM
RE: 37-116 and 118 - by morzh - 07-12-2014, 10:36 PM
RE: 37-116 and 118 - by RadioSvit - 07-14-2014, 12:24 PM
RE: 37-116 and 118 - by morzh - 07-14-2014, 12:26 PM
RE: 37-116 and 118 - by RadioSvit - 07-14-2014, 02:04 PM
RE: 37-116 and 118 - by morzh - 07-14-2014, 02:51 PM
RE: 37-116 and 118 - by morzh - 07-17-2014, 03:18 PM
