  • 1 Vote(s) - 5 Average
Philco 37-690
#45
Here's something about the chassis mount resistors: They are encased within their own heat sinks, but are designed to be mounted to metal for maximum heat dissipation. As a result, they are smaller than their ceramic brethren.
A 50 watt ceramic resistor is 4 inches long. The same 50 watt heatsinked chassis mount resistor is less than 3 inches long.
If the ceramic resistor gets hot due to the amount of current flowing through it and the watts dissipated by it, the surrounding air will become hot. Anything very close to the resistor, or touching it, will also get hot.
If the heatsinked resistor gets hot, the area of the chassis where it is mounted gets just as hot.
This is why I was considering replacing the heatsinked resistors with ceramic.
Your thoughts before I proceed to merely move the 3K heatsinked resistor are welcome.
Philco 37-690 - by Ron Ramirez - 05-30-2014, 08:22 PM
RE: Philco 37-690 - by morzh - 05-30-2014, 08:31 PM
RE: Philco 37-690 - by Eliot Ness - 05-30-2014, 08:42 PM
RE: Philco 37-690 - by morzh - 05-30-2014, 09:16 PM
RE: Philco 37-690 - by Ron Ramirez - 05-30-2014, 09:29 PM
RE: Philco 37-690 - by Eliot Ness - 05-30-2014, 09:41 PM
RE: Philco 37-690 - by morzh - 05-30-2014, 10:49 PM
RE: Philco 37-690 - by Arran - 05-31-2014, 02:10 AM
RE: Philco 37-690 - by Eliot Ness - 05-31-2014, 08:14 AM
RE: Philco 37-690 - by Joeztech - 06-01-2014, 08:58 PM
RE: Philco 37-690 - by Ron Ramirez - 06-02-2014, 05:32 AM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 09:45 AM
RE: Philco 37-690 - by Ron Ramirez - 06-02-2014, 09:53 AM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 12:04 PM
RE: Philco 37-690 - by morzh - 06-02-2014, 12:28 PM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 12:34 PM
RE: Philco 37-690 - by bfrohwein - 06-02-2014, 01:03 PM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 02:09 PM
RE: Philco 37-690 - by Ron Ramirez - 06-02-2014, 05:21 PM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 09:03 PM
RE: Philco 37-690 - by bfrohwein - 06-03-2014, 12:14 AM
RE: Philco 37-690 - by Eliot Ness - 06-03-2014, 09:10 AM
RE: Philco 37-690 - by Ron Ramirez - 06-13-2014, 08:11 AM
RE: Philco 37-690 - by y2kbruce - 06-13-2014, 03:09 PM
RE: Philco 37-690 - by morzh - 06-13-2014, 03:10 PM
RE: Philco 37-690 - by Ron Ramirez - 06-13-2014, 03:59 PM
RE: Philco 37-690 - by Ron Ramirez - 07-01-2014, 09:28 PM
RE: Philco 37-690 - by Arran - 07-01-2014, 11:44 PM
RE: Philco 37-690 - by Ron Ramirez - 07-02-2014, 05:31 AM
RE: Philco 37-690 - by jerryhawthorne - 07-02-2014, 03:37 PM
RE: Philco 37-690 - by Ron Ramirez - 07-03-2014, 10:58 PM
RE: Philco 37-690 - by morzh - 07-03-2014, 11:19 PM
RE: Philco 37-690 - by Ron Ramirez - 07-04-2014, 11:45 AM
RE: Philco 37-690 - by morzh - 07-04-2014, 12:40 PM
RE: Philco 37-690 - by Ron Ramirez - 07-05-2014, 07:29 AM
RE: Philco 37-690 - by morzh - 07-05-2014, 09:40 AM
RE: Philco 37-690 - by Ron Ramirez - 07-17-2014, 08:55 PM
RE: Philco 37-690 - by Mondial - 07-17-2014, 09:56 PM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 05:51 AM
RE: Philco 37-690 - by Mondial - 07-18-2014, 06:43 AM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 07:26 AM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 07:30 AM
RE: Philco 37-690 - by Mondial - 07-18-2014, 08:02 AM
RE: Philco 37-690 - by morzh - 07-18-2014, 09:10 AM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 10:00 AM
RE: Philco 37-690 - by Phlogiston - 07-18-2014, 10:01 AM
RE: Philco 37-690 - by Mondial - 07-18-2014, 03:12 PM
RE: Philco 37-690 - by morzh - 07-18-2014, 04:03 PM
RE: Philco 37-690 - by y2kbruce - 07-18-2014, 05:37 PM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 05:48 PM
RE: Philco 37-690 - by morzh - 07-18-2014, 06:33 PM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 07:21 PM
RE: Philco 37-690 - by Ron Ramirez - 07-20-2014, 09:16 PM
RE: Philco 37-690 - by Ron Ramirez - 07-21-2014, 07:21 PM
Users browsing this thread: 16 Guest(s)
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4105 online users. [Complete List]
» 1 Member(s) | 4104 Guest(s)
