  • 1 Vote(s) - 5 Average
Philco 37-690
#50
Bruce - The transformers do not seem to be running hot. I'll be puling it out again over the weekend and will move the 3K resistor to a more "open" part of the chassis, and will recheck the transformers. That is an excellent idea you have, to run your "warm" sets at 105-110V. In my experience, all of the old radios seem to prefer 110V: any more than that and the majority start running warmer than they probably should.
Mike (Morzh) - No, my fingers did not immediately get burned upon touching the chassis where the 3K and 2.2K are currently mounted, but I think they would have been burned had I held my hand there for more than a few seconds. My main concern is the wood cabinet. If splitting the two resistors up will help - thus dividing the heat between two places - I'm all for it. My friend likes to be able to play his radios for hours. I just want to be sure this one is safe to do that before I release it. I will probably do a test run of my own with everything in the cabinet, a good "burn in" (no pun intended) of 3-4 hours, to see how it does, once I move the 3K resistor.
Russ (Phlog) - I have not. Perhaps I should.
Mondial - Great info, thanks.
And if anyone reading this thread has a working 37-690, preferably with the original 3K/2240 ohm Candohm in place, I would like to know if the chassis gets red hot where the Candohm is mounted after the set plays for an hour or two - just to satisfy my curiosity. As Mondial and Morzh have stated, it probably does get hot. Dry, brittle wiring in the vicinity of the Candohm in this 37-690 seems to bear that out - which is why I replaced all of the speaker wires (the originals were very dry, brittle and cracking, since they all go in to the chassis just above where the Candohm was mounted).
Philco 37-690 - by Ron Ramirez - 05-30-2014, 08:22 PM
RE: Philco 37-690 - by morzh - 05-30-2014, 08:31 PM
RE: Philco 37-690 - by Eliot Ness - 05-30-2014, 08:42 PM
RE: Philco 37-690 - by morzh - 05-30-2014, 09:16 PM
RE: Philco 37-690 - by Ron Ramirez - 05-30-2014, 09:29 PM
RE: Philco 37-690 - by Eliot Ness - 05-30-2014, 09:41 PM
RE: Philco 37-690 - by morzh - 05-30-2014, 10:49 PM
RE: Philco 37-690 - by Arran - 05-31-2014, 02:10 AM
RE: Philco 37-690 - by Eliot Ness - 05-31-2014, 08:14 AM
RE: Philco 37-690 - by Joeztech - 06-01-2014, 08:58 PM
RE: Philco 37-690 - by Ron Ramirez - 06-02-2014, 05:32 AM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 09:45 AM
RE: Philco 37-690 - by Ron Ramirez - 06-02-2014, 09:53 AM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 12:04 PM
RE: Philco 37-690 - by morzh - 06-02-2014, 12:28 PM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 12:34 PM
RE: Philco 37-690 - by bfrohwein - 06-02-2014, 01:03 PM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 02:09 PM
RE: Philco 37-690 - by Ron Ramirez - 06-02-2014, 05:21 PM
RE: Philco 37-690 - by Phlogiston - 06-02-2014, 09:03 PM
RE: Philco 37-690 - by bfrohwein - 06-03-2014, 12:14 AM
RE: Philco 37-690 - by Eliot Ness - 06-03-2014, 09:10 AM
RE: Philco 37-690 - by Ron Ramirez - 06-13-2014, 08:11 AM
RE: Philco 37-690 - by y2kbruce - 06-13-2014, 03:09 PM
RE: Philco 37-690 - by morzh - 06-13-2014, 03:10 PM
RE: Philco 37-690 - by Ron Ramirez - 06-13-2014, 03:59 PM
RE: Philco 37-690 - by Ron Ramirez - 07-01-2014, 09:28 PM
RE: Philco 37-690 - by Arran - 07-01-2014, 11:44 PM
RE: Philco 37-690 - by Ron Ramirez - 07-02-2014, 05:31 AM
RE: Philco 37-690 - by jerryhawthorne - 07-02-2014, 03:37 PM
RE: Philco 37-690 - by Ron Ramirez - 07-03-2014, 10:58 PM
RE: Philco 37-690 - by morzh - 07-03-2014, 11:19 PM
RE: Philco 37-690 - by Ron Ramirez - 07-04-2014, 11:45 AM
RE: Philco 37-690 - by morzh - 07-04-2014, 12:40 PM
RE: Philco 37-690 - by Ron Ramirez - 07-05-2014, 07:29 AM
RE: Philco 37-690 - by morzh - 07-05-2014, 09:40 AM
RE: Philco 37-690 - by Ron Ramirez - 07-17-2014, 08:55 PM
RE: Philco 37-690 - by Mondial - 07-17-2014, 09:56 PM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 05:51 AM
RE: Philco 37-690 - by Mondial - 07-18-2014, 06:43 AM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 07:26 AM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 07:30 AM
RE: Philco 37-690 - by Mondial - 07-18-2014, 08:02 AM
RE: Philco 37-690 - by morzh - 07-18-2014, 09:10 AM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 10:00 AM
RE: Philco 37-690 - by Phlogiston - 07-18-2014, 10:01 AM
RE: Philco 37-690 - by Mondial - 07-18-2014, 03:12 PM
RE: Philco 37-690 - by morzh - 07-18-2014, 04:03 PM
RE: Philco 37-690 - by y2kbruce - 07-18-2014, 05:37 PM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 05:48 PM
RE: Philco 37-690 - by morzh - 07-18-2014, 06:33 PM
RE: Philco 37-690 - by Ron Ramirez - 07-18-2014, 07:21 PM
RE: Philco 37-690 - by Ron Ramirez - 07-20-2014, 09:16 PM
RE: Philco 37-690 - by Ron Ramirez - 07-21-2014, 07:21 PM
New member
Philco 630csx power cord
New member
There are currently 3986 online users. [Complete List]
» 1 Member(s) | 3985 Guest(s)
