coils, repair?
I often reheat the solder on coil terminals and use some rosin core flux or add a small amount of new solder along with some rosin flux to renew the connection. If there was a poor solder connection in the beginning it will often establish a new good connection. the soldering operation does not create the stress that pushing on an old coil terminal with an ohm meter probe/s would. Some good needle-point ohm meter probes do help in dealing with old oxidized solder.
Joe
KC5LY
coils, repair? - by murf - 07-19-2014, 10:34 PM
RE: coils, repair? - by morzh - 07-19-2014, 11:10 PM
RE: coils, repair? - by Arran - 07-20-2014, 08:34 AM
RE: coils, repair? - by morzh - 07-20-2014, 09:24 AM
RE: coils, repair? - by gregb - 07-20-2014, 11:22 AM
RE: coils, repair? - by morzh - 07-20-2014, 11:41 AM
RE: coils, repair? - by Joeztech - 07-20-2014, 02:31 PM
RE: coils, repair? - by gregb - 07-20-2014, 03:14 PM
RE: coils, repair? - by murf - 07-20-2014, 09:04 PM
RE: coils, repair? - by Ron Ramirez - 07-20-2014, 09:11 PM
RE: coils, repair? - by murf - 08-12-2014, 04:59 PM
RE: coils, repair? - by Joeztech - 08-13-2014, 06:24 AM
RE: coils, repair? - by murf - 08-13-2014, 08:21 PM
RE: coils, repair? - by Joeztech - 08-13-2014, 09:42 PM
New member
Philco 630csx power cord
New member
There are currently 4025 online users. [Complete List]
» 1 Member(s) | 4024 Guest(s)
