39-25 Project
#32
The paint stuck pretty well. I did rough up the tubing with some 220 grit sand paper and I think that helped. It took a couple coats for the base coat; I'd put some on, hit with the heat gun for a few seconds to dry and put another coat on and sometimes a third coat just to make the color even. I used Americana Acrylic paint. Easy to use and easy to mix for custom colors.
39-25 Project - by klondike98 - 02-07-2014, 12:11 AM
RE: 39-25 Project - by tab10672 - 02-07-2014, 12:14 AM
RE: 39-25 Project - by morzh - 02-07-2014, 10:56 AM
RE: 39-25 Project - by klondike98 - 02-07-2014, 11:36 AM
RE: 39-25 Project - by klondike98 - 02-20-2014, 10:40 AM
RE: 39-25 Project - by Tom Hamilton - 02-25-2014, 12:57 PM
RE: 39-25 Project - by klondike98 - 02-25-2014, 02:08 PM
RE: 39-25 Project - by klondike98 - 02-25-2014, 02:53 PM
RE: 39-25 Project - by Tom Hamilton - 02-25-2014, 07:22 PM
RE: 39-25 Project - by shaler78 - 02-25-2014, 08:42 PM
RE: 39-25 Project - by klondike98 - 02-25-2014, 11:17 PM
RE: 39-25 Project - by klondike98 - 03-08-2014, 11:07 PM
RE: 39-25 Project - by Ron Ramirez - 03-09-2014, 12:14 AM
RE: 39-25 Project - by klondike98 - 03-09-2014, 08:30 AM
RE: 39-25 Project - by Joeztech - 03-23-2014, 04:12 PM
RE: 39-25 Project - by klondike98 - 03-23-2014, 04:48 PM
RE: 39-25 Project - by morzh - 03-23-2014, 06:10 PM
RE: 39-25 Project - by klondike98 - 03-23-2014, 06:27 PM
RE: 39-25 Project - by OldRestorer - 03-23-2014, 09:38 PM
RE: 39-25 Project - by klondike98 - 03-25-2014, 02:04 PM
RE: 39-25 Project - by Chuck Schwark - 03-25-2014, 02:21 PM
RE: 39-25 Project - by klondike98 - 03-25-2014, 02:34 PM
RE: 39-25 Project - by Tom Hamilton - 03-26-2014, 01:51 AM
RE: 39-25 Project - by klondike98 - 07-15-2014, 07:27 PM
RE: 39-25 Project - by klondike98 - 07-15-2014, 07:50 PM
RE: 39-25 Project - by morzh - 07-15-2014, 09:09 PM
RE: 39-25 Project - by klondike98 - 07-16-2014, 10:43 AM
RE: 39-25 Project - by morzh - 07-16-2014, 03:57 PM
RE: 39-25 Project - by klondike98 - 07-16-2014, 08:22 PM
RE: 39-25 Project - by klondike98 - 07-21-2014, 12:26 PM
RE: 39-25 Project - by Radioroslyn - 07-21-2014, 01:18 PM
RE: 39-25 Project - by klondike98 - 07-21-2014, 05:27 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2556 online users. [Complete List]
» 1 Member(s) | 2555 Guest(s)
