Importance of grounding.
I wonder how the proper grounding effects operation of a radio.
For example, my 70 receives plenty with a 10ft of wire with no ground.On another hand, Atwater 84, which came with a 30 ft of old antenna wire will not accept anything shorter than that and only when I drop the first 10 ft on the ground and then raise it up.With all 30ft up it does not do as good. Now, if I ground the set, then it is completely different story-I can raise the entire 30 ft and it operates as great as my 70.
P.S.Both sets are aligned as per instructions.
Importance of grounding. - by fields 100 - 07-23-2014, 01:30 PM
RE: Importance of grounding. - by Mondial - 07-23-2014, 02:02 PM
RE: Importance of grounding. - by fields 100 - 07-23-2014, 02:11 PM
RE: Importance of grounding. - by morzh - 07-23-2014, 02:27 PM
RE: Importance of grounding. - by gregb - 07-23-2014, 06:10 PM
RE: Importance of grounding. - by fields 100 - 07-23-2014, 06:32 PM
RE: Importance of grounding. - by gregb - 07-23-2014, 06:54 PM
RE: Importance of grounding. - by morzh - 07-23-2014, 07:45 PM
RE: Importance of grounding. - by gregb - 07-23-2014, 07:53 PM
RE: Importance of grounding. - by morzh - 07-23-2014, 07:54 PM
RE: Importance of grounding. - by gregb - 07-23-2014, 08:02 PM
RE: Importance of grounding. - by Arran - 07-23-2014, 11:50 PM
