Found another 66B
Great ind.
Mine was I think (another cabinet) over a 100 and no shields, plus as I found out yesterday all magnetics are dead.
Found another 66B - by Eric Adams - 07-24-2014, 02:22 PM
RE: Found another 66B - by morzh - 07-24-2014, 03:05 PM
RE: Found another 66B - by Arran - 07-24-2014, 06:20 PM
RE: Found another 66B - by OldRestorer - 07-24-2014, 08:21 PM
RE: Found another 66B - by klondike98 - 07-24-2014, 08:50 PM
RE: Found another 66B - by morzh - 07-24-2014, 08:54 PM
There are currently 8921 online users. [Complete List]
» 3 Member(s) | 8918 Guest(s)
