Thoughts about a 1936 630 ?
All the 1936 "600" series sets are decent performers, once refurbished.
All the usual caveats on restoration, of course.
Chuck
Thoughts about a 1936 630 ? - by Warren - 07-24-2014, 02:29 PM
RE: Thoughts about a 1936 630 ? - by Chuck Schwark - 07-24-2014, 03:53 PM
RE: Thoughts about a 1936 630 ? - by tab10672 - 07-24-2014, 04:51 PM
RE: Thoughts about a 1936 630 ? - by Arran - 07-24-2014, 06:06 PM
RE: Thoughts about a 1936 630 ? - by Warren - 07-24-2014, 06:13 PM
RE: Thoughts about a 1936 630 ? - by Warren - 07-24-2014, 06:21 PM
RE: Thoughts about a 1936 630 ? - by Arran - 07-24-2014, 06:24 PM
RE: Thoughts about a 1936 630 ? - by Warren - 07-24-2014, 08:08 PM
RE: Thoughts about a 1936 630 ? - by Mondial - 07-24-2014, 08:22 PM
RE: Thoughts about a 1936 630 ? - by Ron Ramirez - 07-24-2014, 08:48 PM
RE: Thoughts about a 1936 630 ? - by Warren - 07-24-2014, 11:05 PM
There are currently 9782 online users. [Complete List]
» 2 Member(s) | 9780 Guest(s)
