GE J-664 filter cap ?
I think 50uf would be OK. It would probably fall within the tolerance of the 60uf. But, since this is the output filter, going a little higher, say up to 100uf wouldn't hurt anything.
M R Radios   C M Tubes
GE J-664 filter cap ? - by Eric - 07-24-2014, 03:38 PM
RE: GE J-664 filter cap ? - by Steve Davis - 07-24-2014, 04:25 PM
RE: GE J-664 filter cap ? - by Eric - 07-24-2014, 07:06 PM
RE: GE J-664 filter cap ? - by Arran - 07-24-2014, 07:52 PM
RE: GE J-664 filter cap ? - by Mondial - 07-24-2014, 08:14 PM
RE: GE J-664 filter cap ? - by Eric - 07-25-2014, 09:14 AM
RE: GE J-664 filter cap ? - by codefox1 - 07-25-2014, 12:03 PM
There are currently 5998 online users. [Complete List]
» 1 Member(s) | 5997 Guest(s)
