Unknown Philco 610
The plate on the chassis would identify it as an export set, the cabinet may have been made locally or may have been made in Philadelphia. I don't think that the speaker is a Philco unit however, the normal 610 would have used a standard table model speaker that would have been of the 8'' pincushion style.
Unknown Philco 610 - by edison - 07-24-2014, 04:17 PM
RE: Unknown Philco 610 - by Arran - 07-24-2014, 06:13 PM
RE: Unknown Philco 610 - by tab10672 - 07-24-2014, 07:34 PM
RE: Unknown Philco 610 - by Ron Ramirez - 07-24-2014, 08:55 PM
RE: Unknown Philco 610 - by edison - 07-25-2014, 06:11 PM
There are currently 9749 online users. [Complete List]
» 2 Member(s) | 9747 Guest(s)
