Starting on 66.
Well that's a new one on me. I wonder why Philco would bother with an extra filter choke in a five tuber like this? The set is more or less a model 60 chassis with different band coverage, so why waste money adding an extra inductor that none of their competitors would have? I wonder if the power supply could be rewired to copy the model 60? It looks like capacitor #49 (5 uf) probably shorted out and damaged that silly choke. Possibly one of the capacitors in the tone control did the same and destroyed the output transformer primary, since it's a single ended #42 finding a replacement should not be a problem, you may even be able to find a salvaged Philco output transformer?
Starting on 66. - by morzh - 07-23-2014, 10:17 PM
RE: Starting on 66. - by Arran - 07-24-2014, 02:58 AM
RE: Starting on 66. - by morzh - 07-24-2014, 09:59 AM
RE: Starting on 66. - by morzh - 07-24-2014, 04:01 PM
RE: Starting on 66. - by Arran - 07-24-2014, 06:46 PM
RE: Starting on 66. - by morzh - 07-24-2014, 09:02 PM
RE: Starting on 66. - by morzh - 08-04-2014, 08:32 PM
RE: Starting on 66. - by morzh - 08-04-2014, 10:42 PM
RE: Starting on 66. - by morzh - 08-05-2014, 09:30 PM
RE: Starting on 66. - by ccomer1955 - 08-07-2014, 04:42 PM
RE: Starting on 66. - by morzh - 08-07-2014, 04:46 PM
RE: Starting on 66. - by ccomer1955 - 08-09-2014, 09:56 AM
RE: Starting on 66. - by morzh - 08-09-2014, 11:24 AM
RE: Starting on 66. - by ccomer1955 - 08-09-2014, 01:58 PM
RE: Starting on 66. - by morzh - 08-09-2014, 04:37 PM
RE: Starting on 66. - by morzh - 08-12-2014, 09:35 PM
RE: Starting on 66. - by Ron Ramirez - 08-12-2014, 10:41 PM
RE: Starting on 66. - by morzh - 08-12-2014, 11:04 PM
RE: Starting on 66. - by Eric Adams - 08-12-2014, 11:39 PM
RE: Starting on 66. - by morzh - 08-13-2014, 12:37 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 01:15 PM
RE: Starting on 66. - by morzh - 08-13-2014, 01:30 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 01:51 PM
RE: Starting on 66. - by sam - 08-13-2014, 02:08 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 02:28 PM
RE: Starting on 66. - by Chuck Schwark - 08-13-2014, 04:28 PM
RE: Starting on 66. - by mikethedruid - 08-13-2014, 06:02 PM
RE: Starting on 66. - by Eric Adams - 08-13-2014, 06:07 PM
RE: Starting on 66. - by morzh - 08-13-2014, 07:38 PM
RE: Starting on 66. - by morzh - 08-13-2014, 08:08 PM
RE: Starting on 66. - by Mondial - 08-13-2014, 08:18 PM
RE: Starting on 66. - by morzh - 08-13-2014, 09:03 PM
RE: Starting on 66. - by morzh - 08-13-2014, 10:27 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 01:09 PM
RE: Starting on 66. - by morzh - 08-14-2014, 01:29 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 01:44 PM
RE: Starting on 66. - by morzh - 08-14-2014, 02:14 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 02:33 PM
RE: Starting on 66. - by morzh - 08-14-2014, 02:42 PM
RE: Starting on 66. - by Eric Adams - 08-14-2014, 03:04 PM
RE: Starting on 66. - by Warren - 08-14-2014, 04:52 PM
RE: Starting on 66. - by morzh - 08-14-2014, 08:46 PM
RE: Starting on 66. - by Eliot Ness - 08-15-2014, 07:48 AM
RE: Starting on 66. - by Eric Adams - 08-15-2014, 10:02 AM
RE: Starting on 66. - by morzh - 08-28-2014, 09:53 PM
RE: Starting on 66. - by Eric Adams - 08-28-2014, 10:07 PM
RE: Starting on 66. - by morzh - 08-28-2014, 10:31 PM
RE: Starting on 66. - by Arran - 08-29-2014, 01:04 AM
RE: Starting on 66. - by Eric Adams - 08-29-2014, 10:18 AM
RE: Starting on 66. - by morzh - 08-29-2014, 11:25 AM
RE: Starting on 66. - by OldRestorer - 08-29-2014, 11:38 AM
RE: Starting on 66. - by morzh - 08-29-2014, 04:51 PM
RE: Starting on 66. - by morzh - 08-29-2014, 05:30 PM
RE: Starting on 66. - by morzh - 08-29-2014, 05:42 PM
RE: Starting on 66. - by morzh - 08-29-2014, 06:14 PM
RE: Starting on 66. - by morzh - 08-29-2014, 10:10 PM
RE: Starting on 66. - by morzh - 08-30-2014, 08:23 PM
RE: Starting on 66. - by morzh - 08-30-2014, 09:41 PM
RE: Starting on 66. - by morzh - 08-30-2014, 09:43 PM
RE: Starting on 66. - by Warren - 08-31-2014, 12:07 AM
RE: Starting on 66. - by OldRestorer - 08-31-2014, 08:47 AM
RE: Starting on 66. - by morzh - 08-31-2014, 10:30 AM
RE: Starting on 66. - by Radioroslyn - 08-31-2014, 10:48 AM
RE: Starting on 66. - by morzh - 08-31-2014, 11:14 AM
RE: Starting on 66. - by OldRestorer - 08-31-2014, 11:16 AM
RE: Starting on 66. - by morzh - 08-31-2014, 11:25 AM
RE: Starting on 66. - by OldRestorer - 08-31-2014, 11:37 AM
RE: Starting on 66. - by morzh - 08-31-2014, 12:11 PM
There are currently 2846 online users. [Complete List]
» 2 Member(s) | 2844 Guest(s)
