Unknown Philco 610
The speaker looks correct to me - the USA 610B used a 5 inch speaker that looks just like that one.
The cabinet may, or may not, have been modified. I seriously doubt that the cabinet was made in the USA, although the chassis clearly was. The cabinet may have been made in Perivale, UK.
Take a look at the French 2620B "Philco-Super-Radio" that I used to own:
[Image: http://www.philcoradio.com/world/images/2620b.jpg]
The chassis in this set was also made in USA. I cannot prove that the cabinet was made in Perivale, but it looks similar to some UK Philco tombstones of the time.
Unknown Philco 610 - by edison - 07-24-2014, 04:17 PM
RE: Unknown Philco 610 - by Arran - 07-24-2014, 06:13 PM
RE: Unknown Philco 610 - by tab10672 - 07-24-2014, 07:34 PM
RE: Unknown Philco 610 - by Ron Ramirez - 07-24-2014, 08:55 PM
RE: Unknown Philco 610 - by edison - 07-25-2014, 06:11 PM
There are currently 8154 online users. [Complete List]
» 1 Member(s) | 8153 Guest(s)
