Philco 38-7CS
Chuck - Yes, the muting switch does work correctly, but I disconnected it anyway to eliminate it as a source of trouble.
Yes, I have checked and swapped the tubes, but no change. It does use AVC so maybe I should monitor the AVC voltage as it warms up ?
Philco 38-7CS - by Bob Andersen - 07-24-2014, 07:32 PM
RE: Philco 38-7CS - by Bob Andersen - 07-24-2014, 07:41 PM
RE: Philco 38-7CS - by Bob Andersen - 07-24-2014, 07:48 PM
RE: Philco 38-7CS - by Bob Andersen - 07-24-2014, 07:57 PM
RE: Philco 38-7CS - by Arran - 07-24-2014, 09:34 PM
RE: Philco 38-7CS - by Bob Andersen - 07-24-2014, 09:50 PM
RE: Philco 38-7CS - by codefox1 - 07-25-2014, 01:34 PM
RE: Philco 38-7CS - by Chuck Schwark - 07-25-2014, 01:46 PM
RE: Philco 38-7CS - by morzh - 07-25-2014, 01:47 PM
RE: Philco 38-7CS - by Bob Andersen - 07-25-2014, 04:24 PM
RE: Philco 38-7CS - by morzh - 07-25-2014, 05:02 PM
RE: Philco 38-7CS - by Arran - 07-26-2014, 12:06 AM
RE: Philco 38-7CS - by Bob Andersen - 07-27-2014, 03:35 PM
RE: Philco 38-7CS - by gregb - 07-27-2014, 11:13 PM
RE: Philco 38-7CS - by Bob Andersen - 07-27-2014, 11:28 PM
RE: Philco 38-7CS - by Bob Andersen - 07-28-2014, 04:16 PM
RE: Philco 38-7CS - by Mondial - 07-28-2014, 04:26 PM
RE: Philco 38-7CS - by Bob Andersen - 07-28-2014, 05:18 PM
RE: Philco 38-7CS - by Mondial - 07-28-2014, 05:36 PM
RE: Philco 38-7CS - by Bob Andersen - 07-28-2014, 06:51 PM
RE: Philco 38-7CS - by Bob Andersen - 07-28-2014, 10:29 PM
RE: Philco 38-7CS - by Chuck Schwark - 07-29-2014, 10:35 AM
RE: Philco 38-7CS - by morzh - 07-29-2014, 10:37 AM
RE: Philco 38-7CS - by Chuck Schwark - 07-29-2014, 10:42 AM
RE: Philco 38-7CS - by morzh - 07-29-2014, 11:02 AM
RE: Philco 38-7CS - by Warren - 07-29-2014, 01:59 PM
RE: Philco 38-7CS - by gregb - 07-29-2014, 03:16 PM
RE: Philco 38-7CS - by Bob Andersen - 07-29-2014, 03:31 PM
RE: Philco 38-7CS - by Bob Andersen - 08-03-2014, 02:06 PM
RE: Philco 38-7CS - by codefox1 - 08-03-2014, 04:29 PM
New member
Philco 630csx power cord
New member
There are currently 4051 online users. [Complete List]
» 1 Member(s) | 4050 Guest(s)
