Advice on electolytic and solid state
Hi folks,
Am working on a 42-380. What electrolytic do I buy for the 8-8 #20 in the diagram?. I'm new and don't understand the nomenclature for this particular rating. The others are straightforward.
Has anyone tried the solid state plug in for the 6X5GT tube, that's out on the web and Ebay?. From what I read, it sounds like a reliable fix.
THanks!!
Advice on electolytic and solid state - by standardtwin - 07-26-2014, 09:43 AM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
