48-482 FM antenna
Leave the antenna connected to the line cord as is, it works very well. The location on the power cord is located 1/4 wavelength at FM broadcast freqs from the internal line to chassis caps which act as a ground to chassis. Therefore, 1/4 wavelength down the power cord, you are at a relative signal voltage maximum and this is where the capacitive coupling to the antenna input is located.
When operating correctly, the reception with the line antenna is excellent.
48-482 FM antenna - by mikethedruid - 07-26-2014, 07:25 PM
RE: 48-482 FM antenna - by Mondial - 07-26-2014, 07:36 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2258 online users. [Complete List]
» 4 Member(s) | 2254 Guest(s)
AvatarAvatarAvatarAvatar
