Cone-centric question
Maybe you can get an idea from the assembly drawings? You may be referring to the Pawl Spring, part No. 23 in drawing?
See the CONE-CENTRIC PAGE on my site:
http://www.philcorepairbench.com/conecentric/index.htm
See the three PDFs on this page for dial assy. Never had one in my hands, so I cannot help from person experience. I think Ron has though....
Chuck
Cone-centric question - by TonyJSenior - 09-18-2008, 01:51 PM
Re: Cone-centric question - by Chuck Schwark - 09-18-2008, 03:16 PM
Re: Cone-centric question - by TonyJSenior - 09-18-2008, 05:06 PM
Re: Cone-centric question - by DCASAZZA - 09-19-2008, 06:55 AM
Re: Cone-centric question - by TonyJSenior - 09-19-2008, 07:14 AM
Re: Cone-centric question - by Chuck Schwark - 09-19-2008, 09:37 AM
Re: Cone-centric question - by Guest - 09-27-2008, 12:37 AM
Philco 91 Tuning Condenser
There are currently 10403 online users. [Complete List]
» 2 Member(s) | 10401 Guest(s)
