garbage day Philco Phind
I recapped one RF chassis, but that was a 37-116. Not looking forward to another one unless it is a 38-690.
garbage day Philco Phind - by OldRestorer - 07-27-2014, 06:44 PM
RE: garbage day Philco Phind - by sam - 07-27-2014, 06:46 PM
RE: garbage day Philco Phind - by SteveJB - 07-27-2014, 07:15 PM
RE: garbage day Philco Phind - by morzh - 07-27-2014, 07:32 PM
RE: garbage day Philco Phind - by tab10672 - 07-27-2014, 07:45 PM
RE: garbage day Philco Phind - by Jayce - 07-27-2014, 07:47 PM
RE: garbage day Philco Phind - by morzh - 07-27-2014, 08:39 PM
RE: garbage day Philco Phind - by Ron Ramirez - 07-27-2014, 09:26 PM
RE: garbage day Philco Phind - by OldRestorer - 07-28-2014, 01:41 PM
RE: garbage day Philco Phind - by morzh - 07-28-2014, 01:47 PM
RE: garbage day Philco Phind - by PAradiogeek - 07-28-2014, 07:03 PM
RE: garbage day Philco Phind - by OldRestorer - 07-28-2014, 07:25 PM
RE: garbage day Philco Phind - by PAradiogeek - 07-29-2014, 10:21 AM
RE: garbage day Philco Phind - by morzh - 07-29-2014, 10:24 AM
RE: garbage day Philco Phind - by PAradiogeek - 07-29-2014, 10:45 AM
RE: garbage day Philco Phind - by OldRestorer - 07-29-2014, 11:52 AM
RE: garbage day Philco Phind - by PhilcoJohn - 07-29-2014, 12:50 PM
There are currently 9794 online users. [Complete List]
» 3 Member(s) | 9791 Guest(s)
