Cone-centric question
That type of "split-spring" gear is called anti-backlash. Keeps the gear teeth tight during meshing. Like was mentioned; takes up the slop.
Cone-centric question - by TonyJSenior - 09-18-2008, 01:51 PM
Re: Cone-centric question - by Chuck Schwark - 09-18-2008, 03:16 PM
Re: Cone-centric question - by TonyJSenior - 09-18-2008, 05:06 PM
Re: Cone-centric question - by DCASAZZA - 09-19-2008, 06:55 AM
Re: Cone-centric question - by TonyJSenior - 09-19-2008, 07:14 AM
Re: Cone-centric question - by Chuck Schwark - 09-19-2008, 09:37 AM
Re: Cone-centric question - by Guest - 09-27-2008, 12:37 AM
Philco 91 Tuning Condenser
There are currently 9976 online users. [Complete List]
» 2 Member(s) | 9974 Guest(s)
