Crosley 124 amperage draw
Mike probably means .5A and .85A which would make more sense on the 3A scale.
These readings would seem reasonable, depending on the tube count of the radios involved.
Crosley 124 amperage draw - by KCMike - 07-28-2014, 03:22 PM
RE: Crosley 124 amperage draw - by morzh - 07-28-2014, 03:35 PM
RE: Crosley 124 amperage draw - by Mondial - 07-28-2014, 04:00 PM
RE: Crosley 124 amperage draw - by KCMike - 07-28-2014, 04:01 PM
RE: Crosley 124 amperage draw - by KCMike - 07-28-2014, 04:07 PM
RE: Crosley 124 amperage draw - by Mondial - 07-28-2014, 04:10 PM
RE: Crosley 124 amperage draw - by KCMike - 07-28-2014, 04:19 PM
RE: Crosley 124 amperage draw - by Mondial - 07-28-2014, 04:32 PM
RE: Crosley 124 amperage draw - by KCMike - 07-28-2014, 04:49 PM
RE: Crosley 124 amperage draw - by morzh - 07-28-2014, 06:29 PM
RE: Crosley 124 amperage draw - by codefox1 - 07-28-2014, 07:45 PM
RE: Crosley 124 amperage draw - by morzh - 07-28-2014, 11:07 PM
RE: Crosley 124 amperage draw - by codefox1 - 07-29-2014, 01:20 AM
RE: Crosley 124 amperage draw - by morzh - 07-29-2014, 10:23 AM
There are currently 5793 online users. [Complete List]
» 1 Member(s) | 5792 Guest(s)
