Philco Mini End Table Radio
I just picked up a small inn table radio with a model 91 Chassis. It uses an external speaker. Looks similar to the 19LZX but has the external speaker. Anyone know what model this set goes by?
Joe Miller
Philco Mini End Table Radio - by jamr005 - 07-28-2014, 09:49 PM
RE: Philco Mini End Table Radio - by Eric Adams - 07-29-2014, 12:35 AM
RE: Philco Mini End Table Radio - by Ron Ramirez - 07-29-2014, 05:35 AM
RE: Philco Mini End Table Radio - by OldRestorer - 07-29-2014, 09:19 AM
RE: Philco Mini End Table Radio - by klondike98 - 07-29-2014, 10:01 AM
RE: Philco Mini End Table Radio - by morzh - 07-29-2014, 10:16 AM
RE: Philco Mini End Table Radio - by jamr005 - 08-03-2014, 10:39 PM
RE: Philco Mini End Table Radio - by morzh - 08-03-2014, 10:51 PM
RE: Philco Mini End Table Radio - by klondike98 - 08-03-2014, 10:57 PM
RE: Philco Mini End Table Radio - by jamr005 - 08-05-2014, 09:42 PM
RE: Philco Mini End Table Radio - by Ron Ramirez - 08-06-2014, 08:43 PM
There are currently 6197 online users. [Complete List]
» 1 Member(s) | 6196 Guest(s)
