Zenith 7-S-363 Electrical Restoration Opinions Requested
Nice job! Icon_biggrin Always rewarding after a such a resto. Yours was more than just a few caps and maybe a resistor or two. I rarely find tubes that are actually bad. I also find a radio is the best tube tester made. If I'm unsure of a tubes condition, I'll swap it out with several if the need arises. I've found in the past that output and rectifier tubes take the biggest pounding.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
[No subject] - by BDM - 07-30-2008, 11:19 PM
[No subject] - by Texasrocker - 07-31-2008, 02:25 AM
[No subject] - by Guest - 07-31-2008, 07:06 PM
[No subject] - by etech - 08-01-2008, 09:49 PM
[No subject] - by Terry Burns - 08-02-2008, 10:19 AM
[No subject] - by Guest - 08-26-2008, 03:53 PM
[No subject] - by etech - 08-26-2008, 10:19 PM
[No subject] - by Michael Dennis - 08-28-2008, 06:42 AM
Re: Zenith 7-S-363 Electrical Restoration Opinions Requested - by BDM - 09-20-2008, 06:37 PM
Philco 91 Tuning Condenser
There are currently 9230 online users. [Complete List]
» 2 Member(s) | 9228 Guest(s)
