Plate voltages for UV-200 tubes
NostalgiaRadioTime Wrote:A little thing called a job has a bad habit of taking away from my radio hobby
I know the feeling, brother! But the job also helps to pay the bills, while spending money on radios doesn't. Icon_smile
RE: Plate voltages for UV200 tubes - by morzh - 07-27-2014, 10:47 PM
RE: Plate voltages for UV-200 tubes - by gregb - 07-27-2014, 10:59 PM
RE: Plate voltages for UV-200 tubes - by Mondial - 07-27-2014, 11:03 PM
RE: Plate voltages for UV-200 tubes - by gregb - 07-27-2014, 11:23 PM
RE: Plate voltages for UV-200 tubes - by gregb - 07-27-2014, 11:40 PM
RE: Plate voltages for UV-200 tubes - by morzh - 07-29-2014, 10:20 AM
RE: Plate voltages for UV-200 tubes - by morzh - 07-29-2014, 11:09 AM
RE: Plate voltages for UV-200 tubes - by gregb - 07-29-2014, 05:59 PM
RE: Plate voltages for UV-200 tubes - by Ron Ramirez - 07-29-2014, 06:07 PM
RE: Plate voltages for UV-200 tubes - by Mondial - 07-29-2014, 06:31 PM
There are currently 3473 online users. [Complete List]
» 1 Member(s) | 3472 Guest(s)
