Grunow Alignment?
I have a Grunow that I am in the process of restoring. It is a
model 532 with a 5H chassis, Riders vol 8 p24 has the schematic but the alignment instructions are not there. Model 566 chassis 5S looks to be the same, can I use these alignment instructions? Nostalgia doesn't list either one and radio museum shows only the schematic.
Any help would be appreciated.
Eric
Grunow Alignment? - by Eric - 07-30-2014, 06:00 PM
RE: Grunow Alignment? - by Arran - 07-30-2014, 07:52 PM
RE: Grunow Alignment? - by Eric - 07-31-2014, 09:46 AM
