Atwater Kent 20 Big Box
After looking at horns here:
http://www.radiolaguy.com/Showcase/Gallery-HornSpkr.htm
I have concluded that my AK horn is a Model L.
Photos to follow later...
Atwater Kent 20 Big Box - by Ron Ramirez - 09-21-2008, 03:10 PM
Re: Atwater Kent 20 Big Box - by Ron Ramirez - 09-21-2008, 03:28 PM
Re: Atwater Kent 20 Big Box - by Alan Douglas - 09-21-2008, 05:47 PM
Re: Atwater Kent 20 Big Box - by etech - 09-21-2008, 05:52 PM
Re: Atwater Kent 20 Big Box - by AI2V - 09-21-2008, 06:04 PM
Re: Atwater Kent 20 Big Box - by Ron Ramirez - 09-21-2008, 09:27 PM
Re: Atwater Kent 20 Big Box - by Texasrocker - 09-25-2008, 12:23 AM
Re: Atwater Kent 20 Big Box - by Ron Ramirez - 10-04-2008, 05:19 PM
Re: Atwater Kent 20 Big Box - by Texasrocker - 10-04-2008, 10:11 PM
Re: Atwater Kent 20 Big Box - by Ron Ramirez - 10-04-2008, 11:08 PM
Re: Atwater Kent 20 Big Box - by Texasrocker - 10-04-2008, 11:29 PM
Re: Atwater Kent 20 Big Box - by Ron Ramirez - 10-04-2008, 11:32 PM
Re: Atwater Kent 20 Big Box - by Texasrocker - 10-06-2008, 02:53 AM
Re: Atwater Kent 20 Big Box- PAINT - by AI2V - 10-06-2008, 11:53 AM
Re: Atwater Kent 20 Big Box - by Guest - 10-06-2008, 02:26 PM
Re: Atwater Kent 20 Big Box - by BILL - 10-06-2008, 05:44 PM
Re: Atwater Kent 20 Big Box - by Ron Ramirez - 10-06-2008, 11:42 PM
Re: Atwater Kent 20 Big Box - by DeckApe - 10-07-2008, 10:41 AM
Re: Atwater Kent 20 Big Box - by Alan Douglas - 10-08-2008, 06:58 PM
Re: Atwater Kent 20 Big Box - by DeckApe - 10-09-2008, 11:51 AM
Re: Atwater Kent 20 Big Box - by BILL - 10-24-2008, 05:45 PM
There are currently 10274 online users. [Complete List]
» 2 Member(s) | 10272 Guest(s)
