My new/old Zenith 7S240 chairside!
If it has a good 6T5 and you have a few more, they are worth more than the radio. The "star" eye tubes are very expensive.
RE: My new/old Zenith 7S240 chairside! - by sam - 08-03-2014, 01:15 PM
RE: My new/old Zenith 7S240 chairside! - by morzh - 08-03-2014, 05:27 PM
RE: My new/old Zenith 7S240 chairside! - by tab10672 - 08-03-2014, 06:33 PM
RE: My new/old Zenith 7S240 chairside! - by morzh - 08-03-2014, 06:33 PM
RE: My new/old Zenith 7S240 chairside! - by JimZ - 08-04-2014, 06:29 PM
RE: My new/old Zenith 7S240 chairside! - by morzh - 08-04-2014, 10:18 PM
RE: My new/old Zenith 7S240 chairside! - by Arran - 08-04-2014, 11:24 PM
RE: My new/old Zenith 7S240 chairside! - by morzh - 08-05-2014, 11:45 AM
RE: My new/old Zenith 7S240 chairside! - by Arran - 08-06-2014, 01:53 AM
There are currently 6043 online users. [Complete List]
» 1 Member(s) | 6042 Guest(s)
