Philco Mini End Table Radio
Has the radio been recapped recently? If not you risk damaging it by not doing so. Post some pics...you can see how at http://www.philcoradio.com/phorum/showth...p?tid=4371
Schematic for the 91 series is available on Nostalgiaair.org
Philco Mini End Table Radio - by jamr005 - 07-28-2014, 09:49 PM
RE: Philco Mini End Table Radio - by Eric Adams - 07-29-2014, 12:35 AM
RE: Philco Mini End Table Radio - by Ron Ramirez - 07-29-2014, 05:35 AM
RE: Philco Mini End Table Radio - by OldRestorer - 07-29-2014, 09:19 AM
RE: Philco Mini End Table Radio - by klondike98 - 07-29-2014, 10:01 AM
RE: Philco Mini End Table Radio - by morzh - 07-29-2014, 10:16 AM
RE: Philco Mini End Table Radio - by jamr005 - 08-03-2014, 10:39 PM
RE: Philco Mini End Table Radio - by morzh - 08-03-2014, 10:51 PM
RE: Philco Mini End Table Radio - by klondike98 - 08-03-2014, 10:57 PM
RE: Philco Mini End Table Radio - by jamr005 - 08-05-2014, 09:42 PM
RE: Philco Mini End Table Radio - by Ron Ramirez - 08-06-2014, 08:43 PM
