Stromberg Carlson 225-H restoration chronicles
Glad you are up and around so you can get back to working some. Good idea sealing prior to grain fill so you don't lean coloring in an unwanted direction.
Some of the guitar joints sell grainfillers specifically for rosewood but I imagine someone could get pretty close maybe altering something brownish with some mahogany to give it some reddish cast...I think that's what I ended up doing years ago. BTW? Where was that repair again? LOL.
RE: Stromberg Carlson 225-H restoration chronicles - by JimZ - 08-04-2014, 06:23 PM
There are currently 6017 online users. [Complete List]
» 1 Member(s) | 6016 Guest(s)
