RCA 66X3
Cool looking, needs a disco ball above it.
I think that burl finish could be easily repeated. printed on paper and glued on. As for the cloth, take some white. fold it tight like a chinese fan and dip it into dark dye for a while. Like tye dye! Dont know if it would work though.
Here is a veneer pic you could replicate
http://www.27estore.com/mahogany-burl
RCA 66X3 - by Paul Philco322 - 08-04-2014, 09:13 PM
RE: RCA 66X3 - by OldRestorer - 08-05-2014, 06:56 AM
RE: RCA 66X3 - by Paul Philco322 - 08-06-2014, 08:45 PM
RE: RCA 66X3 - by Eric Adams - 08-06-2014, 11:48 PM
RE: RCA 66X3 - by Arran - 08-08-2014, 12:50 AM
There are currently 6056 online users. [Complete List]
» 2 Member(s) | 6054 Guest(s)
