new project 48-482
Good job, Mike.
And, speaking of FM, unless you use good antenna, it will be weakish. My stereo tuner, in fact both of them, sold state from 90s, barely work on a wire piece.
new project 48-482 - by mikethedruid - 07-25-2014, 05:56 PM
RE: new project 48-482 - by klondike98 - 07-25-2014, 11:15 PM
RE: new project 48-482 - by Eric Adams - 07-26-2014, 12:10 AM
RE: new project 48-482 - by klondike98 - 07-26-2014, 08:42 AM
RE: new project 48-482 - by mikethedruid - 07-26-2014, 03:47 PM
RE: new project 48-482 - by mikethedruid - 08-05-2014, 10:05 PM
RE: new project 48-482 - by morzh - 08-05-2014, 10:44 PM
RE: new project 48-482 - by klondike98 - 08-05-2014, 11:24 PM
RE: new project 48-482 - by Eric Adams - 08-06-2014, 12:28 AM
RE: new project 48-482 - by mikethedruid - 08-06-2014, 01:13 AM
RE: new project 48-482 - by Tom Hamilton - 08-10-2014, 09:22 PM
RE: new project 48-482 - by mikethedruid - 08-19-2014, 05:35 PM
RE: new project 48-482 - by klondike98 - 08-20-2014, 11:13 AM
