My 48-482 project
LOL... I have the chassis back out of the cabinet, and am going to replace Z404 with a replica I made by wrapping paper around a .01 cap to which I soldered, close to the body, a piece of #24 stranded insulated wire. I wrapped the cap with paper to increase the diameter and length to approximate that of the original .01 paper cap. I had measured the wire to approximate the length of one leg of a TV rabbit ear, which seems to be about the length of the wire wrapped on the original, if not a bit more. We'll see if this makes a difference. I am also going to replace a number of resistors that set various voltages in the power supply and the bias voltage dividers for the FM section. I really think the set can perform better on FM than it is now. I am going to wait to start the work until I have all the resistors in before I begin again. We shall see.
My 48-482 project - by mikethedruid - 07-26-2014, 03:32 PM
RE: My 48-482 project - by morzh - 07-26-2014, 05:40 PM
RE: My 48-482 project - by codefox1 - 07-26-2014, 05:44 PM
RE: My 48-482 project - by Mondial - 07-26-2014, 07:15 PM
RE: My 48-482 project - by mikethedruid - 07-27-2014, 11:19 PM
RE: My 48-482 project - by klondike98 - 07-28-2014, 11:03 AM
RE: My 48-482 project - by mikethedruid - 07-28-2014, 06:45 PM
RE: My 48-482 project - by mikethedruid - 07-31-2014, 06:22 PM
RE: My 48-482 project - by morzh - 07-31-2014, 07:49 PM
RE: My 48-482 project - by mikethedruid - 07-31-2014, 08:52 PM
RE: My 48-482 project - by mikethedruid - 08-03-2014, 02:59 AM
RE: My 48-482 project - by klondike98 - 08-03-2014, 11:07 AM
RE: My 48-482 project - by mikethedruid - 08-03-2014, 11:24 AM
RE: My 48-482 project - by Mondial - 08-03-2014, 07:04 PM
RE: My 48-482 project - by tom.seeger - 08-03-2014, 11:53 PM
RE: My 48-482 project - by mikethedruid - 08-04-2014, 05:47 AM
RE: My 48-482 project - by mikethedruid - 08-05-2014, 12:18 AM
RE: My 48-482 project - by Mondial - 08-05-2014, 08:19 PM
RE: My 48-482 project - by mikethedruid - 08-05-2014, 10:18 PM
RE: My 48-482 project - by mikethedruid - 08-06-2014, 08:03 PM
RE: My 48-482 project - by klondike98 - 08-06-2014, 10:13 PM
RE: My 48-482 project - by mikethedruid - 08-07-2014, 03:18 PM
RE: My 48-482 project - by mikethedruid - 08-08-2014, 12:41 PM
RE: My 48-482 project - by tom.seeger - 08-08-2014, 11:53 PM
RE: My 48-482 project - by Warren - 08-09-2014, 12:13 AM
RE: My 48-482 project - by mikethedruid - 08-09-2014, 02:42 AM
RE: My 48-482 project - by mikethedruid - 08-15-2014, 03:34 PM
RE: My 48-482 project - by klondike98 - 08-15-2014, 04:36 PM
RE: My 48-482 project - by mikethedruid - 08-15-2014, 10:04 PM
RE: My 48-482 project - by mikethedruid - 08-19-2014, 04:53 PM
RE: My 48-482 project - by mikethedruid - 08-19-2014, 11:47 PM
RE: My 48-482 project - by Michael - 10-07-2014, 07:14 PM
RE: My 48-482 project - by klondike98 - 10-08-2014, 08:01 PM
RE: My 48-482 project - by mikethedruid - 10-09-2014, 02:07 AM
RE: My 48-482 project - by Michael - 10-12-2014, 01:17 PM
RE: My 48-482 project - by Ron Ramirez - 10-12-2014, 04:04 PM
RE: My 48-482 project - by LASJayhawk - 10-12-2014, 04:59 PM
RE: My 48-482 project - by Michael - 10-18-2014, 08:19 PM
RE: My 48-482 project - by Mondial - 10-18-2014, 08:55 PM
RE: My 48-482 project - by Michael - 10-22-2014, 03:10 PM
RE: My 48-482 project - by Michael - 11-09-2014, 05:21 PM
RE: My 48-482 project - by mikethedruid - 11-10-2014, 04:16 PM
There are currently 2716 online users. [Complete List]
» 1 Member(s) | 2715 Guest(s)
