Philco Mini End Table Radio
First, pictures of jamr005's Philco chairside and the cathedral speaker:
[Image: http://i326.photobucket.com/albums/k420/...g~original]
Now, having this information, I know what this is: The chairside is a 14LZX from early 1933.
http://www.philcoradio.com/gallery/1933a.htm#a
The 14LZX uses the same chassis as model 91. The tube layout sticker inside should state "Model 91 and 14 Series".
Now, the speaker: It is a 1932 model R-3 extension speaker. This speaker was introduced with Philco's new lineup of radios in June 1932. A picture of one may be seen in this site's History section at this link:
http://www.philcoradio.com/history/othrphil.htm
Top row, fourth photo from left.
Philco Mini End Table Radio - by jamr005 - 07-28-2014, 09:49 PM
RE: Philco Mini End Table Radio - by Eric Adams - 07-29-2014, 12:35 AM
RE: Philco Mini End Table Radio - by Ron Ramirez - 07-29-2014, 05:35 AM
RE: Philco Mini End Table Radio - by OldRestorer - 07-29-2014, 09:19 AM
RE: Philco Mini End Table Radio - by klondike98 - 07-29-2014, 10:01 AM
RE: Philco Mini End Table Radio - by morzh - 07-29-2014, 10:16 AM
RE: Philco Mini End Table Radio - by jamr005 - 08-03-2014, 10:39 PM
RE: Philco Mini End Table Radio - by morzh - 08-03-2014, 10:51 PM
RE: Philco Mini End Table Radio - by klondike98 - 08-03-2014, 10:57 PM
RE: Philco Mini End Table Radio - by jamr005 - 08-05-2014, 09:42 PM
RE: Philco Mini End Table Radio - by Ron Ramirez - 08-06-2014, 08:43 PM
