Band switch Model 60
Thanks, Steve. Was trying to eliminate any potential signal killer. Radio went silent when I was working on getting SW to work and I was working with band switch that was real loosey goosey. I might have to bake the IF coils...my next desperate theory to find what is killing the signal. They ohm right on the money though? My audio works but the RF signal doesn't get thru for some reason.
Band switch Model 60 - by sjhs1962 - 07-06-2014, 10:27 AM
RE: Band switch Model 60 - by sjhs1962 - 07-06-2014, 12:36 PM
RE: Band switch Model 60 - by morzh - 07-06-2014, 02:16 PM
RE: Band switch Model 60 - by sjhs1962 - 07-06-2014, 07:12 PM
RE: Band switch Model 60 - by sjhs1962 - 07-06-2014, 09:35 PM
RE: Band switch Model 60 - by morzh - 07-06-2014, 10:02 PM
RE: Band switch Model 60 - by sjhs1962 - 07-07-2014, 05:30 PM
RE: Band switch Model 60 - by sjhs1962 - 07-11-2014, 08:55 PM
RE: Band switch Model 60 - by codefox1 - 07-13-2014, 01:21 PM
RE: Band switch Model 60 - by sjhs1962 - 07-25-2014, 11:50 AM
RE: Band switch Model 60 - by codefox1 - 07-25-2014, 12:16 PM
RE: Band switch Model 60 - by sjhs1962 - 08-06-2014, 09:05 PM
RE: Band switch Model 60 - by Steve Davis - 08-06-2014, 10:12 PM
RE: Band switch Model 60 - by sjhs1962 - 08-07-2014, 11:26 AM
RE: Band switch Model 60 - by sjhs1962 - 08-11-2014, 08:25 PM
RE: Band switch Model 60 - by sjhs1962 - 08-12-2014, 04:41 PM
RE: Band switch Model 60 - by morzh - 08-12-2014, 05:17 PM
RE: Band switch Model 60 - by Steve Davis - 08-12-2014, 06:05 PM
RE: Band switch Model 60 - by sjhs1962 - 08-14-2014, 12:07 PM
RE: Band switch Model 60 - by morzh - 08-14-2014, 01:32 PM
RE: Band switch Model 60 - by sjhs1962 - 08-16-2014, 04:56 PM
RE: Band switch Model 60 - by morzh - 08-16-2014, 05:15 PM
RE: Band switch Model 60 - by winston763 - 08-20-2014, 08:49 AM
RE: Band switch Model 60 - by sjhs1962 - 08-20-2014, 09:22 PM
RE: Band switch Model 60 - by morzh - 08-20-2014, 09:40 PM
RE: Band switch Model 60 - by ccomer1955 - 08-20-2014, 11:21 PM
RE: Band switch Model 60 - by winston763 - 08-20-2014, 11:27 PM
RE: Band switch Model 60 - by morzh - 08-21-2014, 07:09 AM
RE: Band switch Model 60 - by winston763 - 08-23-2014, 01:49 AM
RE: Band switch Model 60 - by morzh - 08-23-2014, 11:28 AM
RE: Band switch Model 60 - by winston763 - 08-24-2014, 01:01 AM
RE: Band switch Model 60 - by sjhs1962 - 08-26-2014, 07:21 PM
There are currently 5511 online users. [Complete List]
» 1 Member(s) | 5510 Guest(s)
