Philco 77 hacked?
Spending more time with this chassis, I have a related question. At what point do you decide to use a chassis for parts instead of repairing? This one has a bad power transformer, bad volume pot, bad fourth RF coil, bad input transformer, and not one single working part for the Model H speaker: open VC, open field coil, open output transformer, shattered spider and disintegrated cone. I COULD source the transformers and pot and find a speaker (Gary at Playthings has them all listed), but the cost would be high. The lowboy cabinet is in pristine condition, though. I want to find the guy who repaired this set in the 40s and punch him.
Philco 77 hacked? - by ccomer1955 - 08-06-2014, 08:02 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 12:15 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 01:15 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 03:29 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 03:38 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 04:36 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-07-2014, 04:37 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 05:44 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-07-2014, 05:47 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 09:07 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 10:54 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 11:42 PM
RE: Philco 77 hacked? - by Arran - 08-08-2014, 03:02 AM
RE: Philco 77 hacked? - by morzh - 08-08-2014, 09:30 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-08-2014, 11:12 AM
RE: Philco 77 hacked? - by Paul Philco322 - 08-08-2014, 12:43 PM
RE: Philco 77 hacked? - by morzh - 08-08-2014, 12:56 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-08-2014, 09:52 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-12-2014, 03:07 PM
RE: Philco 77 hacked? - by morzh - 08-12-2014, 03:38 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-12-2014, 10:05 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-23-2014, 03:04 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-24-2014, 08:04 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-24-2014, 10:35 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-25-2014, 01:28 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-28-2014, 11:56 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-29-2014, 05:31 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-29-2014, 12:31 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-29-2014, 05:39 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-29-2014, 06:17 PM
RE: Philco 77 hacked? - by ccomer1955 - 09-01-2014, 11:54 AM
RE: Philco 77 hacked? - by ccomer1955 - 09-15-2014, 02:08 PM
RE: Philco 77 hacked? - by OZ4 - 09-16-2014, 01:41 PM
RE: Philco 77 hacked? - by ccomer1955 - 09-16-2014, 05:34 PM
There are currently 9893 online users. [Complete List]
» 2 Member(s) | 9891 Guest(s)
