48-482 push button coil winding specs ?
Mike
can you count turns and measure the bobbin diameter?
The wire gauge is not that important as long as you can keep the average area of the winding the same which is simple if it is one layer coil.
RE: 48-482 push button coil winding specs ? - by morzh - 08-07-2014, 06:10 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4098 online users. [Complete List]
» 1 Member(s) | 4097 Guest(s)
