Brunswick Panatrope with Radio S31
Update on the Brunswick. Got all the tubes together finally. I subbed an 11-20 ballast for the non-existant D-110 (got it from playthings of the past). It has a few issues but is working. The turntable works, the pick-up is working but weak. I get a loud hum when I switch to "record" from "radio". It took me a while to get the radio working. The first 24 tube (right side looking in) would not light up at first, then finally did after some cleaning of the pins. I also discovered that while the tuning dial moves when the knob is turned, the tuning capacitor plates do not, so I had to tune it by hand. Volume control for the radio has one setting...loud. Hey, at least it works!
RE: Brunswick Panatrope with Radio S31 - by morzh - 07-11-2014, 05:14 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-13-2014, 08:46 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-14-2014, 10:37 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-16-2014, 10:45 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-16-2014, 12:21 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-17-2014, 12:51 PM
RE: Brunswick Panatrope with Radio S31 - by Groundhog74 - 08-08-2014, 06:29 AM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:39 AM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:55 AM
There are currently 3418 online users. [Complete List]
» 1 Member(s) | 3417 Guest(s)
