Grundig 5005w radio
Looking for a way to rig up an antenna for the shortwave bands.
There is a separate female receptacle that has holes for 3 pins.
I am wondering if each of these holes is to supply an antenna for each of the separate shortwave bands?
The am bands(there are 2)I believe must be supplied a signal through each of the 2 holes on that loop plug that also has 2 pins?
Anyone care to straighten me out on these?
murf
Grundig 5005w radio - by murf - 08-06-2014, 07:49 PM
RE: Grundig 5005w radio - by Paul Philco322 - 08-06-2014, 08:47 PM
RE: Grundig 5005w radio - by murf - 08-06-2014, 09:23 PM
RE: Grundig 5005w radio - by murf - 08-08-2014, 06:44 AM
RE: Grundig 5005w radio - by Ron Ramirez - 08-10-2014, 07:26 AM
RE: Grundig 5005w radio - by Art Hoch - 08-11-2014, 02:37 PM
RE: Grundig 5005w radio - by murf - 08-11-2014, 10:17 PM
RE: Grundig 5005w radio - by Art Hoch - 08-11-2014, 10:49 PM
RE: Grundig 5005w radio - by Ron Ramirez - 08-12-2014, 06:25 AM
RE: Grundig 5005w radio - by murf - 08-12-2014, 07:35 PM
There are currently 3486 online users. [Complete List]
» 1 Member(s) | 3485 Guest(s)
