Brunswick Panatrope with Radio S31
If you posted the link it'd be easier.
The buzz could come due to bad shielding or bad grounding, epecially if it is around the pickup.
RE: Brunswick Panatrope with Radio S31 - by morzh - 07-11-2014, 05:14 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-13-2014, 08:46 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-14-2014, 10:37 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-16-2014, 10:45 AM
RE: Brunswick Panatrope with Radio S31 - by sam - 07-16-2014, 12:21 PM
RE: Brunswick Panatrope with Radio S31 - by Arran - 07-17-2014, 12:51 PM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:39 AM
RE: Brunswick Panatrope with Radio S31 - by morzh - 08-08-2014, 09:55 AM
There are currently 3520 online users. [Complete List]
» 1 Member(s) | 3519 Guest(s)
